print head buries
js1515
print head buries
Post by js1515 »
Hello My orion is having an issue where every time I home it buries the print head into the bed is my best bet to flash the machine? Any help would be appreciated
Now if you'll excuse me, I'm going to go on an overnight drunk, and in 10 days I'm going to set out to find the shark that ate my friend and destroy it. Anyone who wants to tag along is more than welcome.
McSlappy
Re: print head buries
Post by McSlappy »
Have you set the Z-height using the LCD?
js1515
Post by js1515 »
yes if I go into the menu and dial it down
js1515
Post by js1515 »
and its weird I was printing just fine I finished a print homed it and then went to re calibrate before doing the next print now nothing makes it home it just always buries the nozzle
I believe you can get this side effect if you accidentally set Z = 0 from the panel at the top.
I'd reset the ZHeight to something reasonable in the EEPROM settings then re zero it from the panel.
FWIW You don;t have to recalibrate between prints, I only ever do it if I change hotend or build surface.
js1515
Post by js1515 »
hmm ok I'll try that but I cant set z=0 from the printer itself I need to do that from the sd card?
You can set the zero using the front panel - follow the instructions in the user guide and you should be good to go.
