Mounting a JHead to the standard effector
Hansen
Post by Hansen »
Hi all
I just bought myself a JHead hot end, and now I am completely confused about the best mount to print for the hot end. I want it to fit the standard effector on the Rostock Mac V2. A mount for a PEEK fan (preferable matching the standard PEEK fan supplied with the printer) would be nice too. Can any of you guys point me to these mounts somewhere?
Hansen
guanu
SeeMeCNC Staff
Re: Mounting a JHead to the standard effector
Post by guanu »
so you need something like http://seemecnc.com/collections/parts-a ... t-hot-ends hmmmmm, where to get one, where to get one... nope, no idea, think yer stuck with designing something ;)
Guanu
Hansen
Post by Hansen »
Mmmm, I've found several JHead mounts, but I am not sure they fit the RMV2 effector. I like this because of the simplicity, but I just can't see how I would mount it (does it fit, or it is designed for another effector?):
http://www.thingiverse.com/thing:253859
Given the number of different mounts... what am I doing different than everybody else? Do people make new effectors too?
Hansen wrote:Mmmm, I've found several JHead mounts, but I am not sure they fit the RMV2 effector. I like this because of the simplicity, but I just can't see how I would mount it (does it fit, or it is designed for another effector?):
Several of the mounts from Thingiverse will work but very few have a place for a peek fan and which one to choose is difficult.
This one works and has a place for a fan although you will need to buy the 30mm fan. I don't think it comes with the fan.
http://www.tricklaser.com/J-Head-Groove ... JHGMNT.htm
I use the TrickLaser J-Head mount myself and it's very nice.
I also have used the TL mount. Brian makes great stuff!
Another one to keep on the radar will be the YellowJacket from my hometown makerspace! Glenn has been working on the design for a while, and his production batch of boards just came in!
[img]https://fbcdn-sphotos-f-a.akamaihd.net/ ... bd8147f4ab[/img]
http://makerhive.proboards.com/thread/1 ... otend-plug
bvandiepenbos
Post by bvandiepenbos »
I saw Glenn's board at last nights meeting... really nice design. Makes a clean install. Easy to unplug and swap out heads if you want.
The board is thick enough to take the place of the stock platform.
Works with a SeeMe hot-end or a groove mount hot-end.
Also has a place to mount a fan.
Jimustanguitar wrote:I also have used the TL mount. Brian makes great stuff!
Would you inform us when they are ready for sale?
Is there a photo of it with the connectors soldered on, but no hot end installed?
Also, "SQUEEEEEE!" *ahem*
geneb wrote:Is there a photo of it with the connectors soldered on, but no hot end installed?
I swear you are starting to lose it!
Post by Mac The Knife »
It's all that flavoured coffee he's been consuming,,,,,,
*slow clap*
(Eagle, you must have it in order to lose it! :D )
DavidF
Post by DavidF »
I just made a Jhead mount. Try it out and see if it works for you.[img]http://i1102.photobucket.com/albums/g446/davidflowers1/utf-8BSU1BRzA3OTMuanBn.jpg[/img]
jmount top.stl
(488.77 KiB) Downloaded 436 times
jmount top.stl
Jmount.stl
(596.75 KiB) Downloaded 573 times
Lost pla castings? see me
DavidF
Post by DavidF »
Maybe someone will find it helpful...
No, but here are some better images.
[img]http://i.imgur.com/cl2iwcw.png[/img]
[img]http://i.imgur.com/foB2hci.png[/img]
[img]http://i.imgur.com/BQLopjg.png[/img]
[img]http://i.imgur.com/UuHasSx.png[/img]
Those would be great if they ever go up for sale.
Eaglezsoar wrote:Would you inform us when they are ready for sale?
http://www.themakerhive.com/shop/viewit ... oductid=18
They're up for sale as of this morning, enjoy!
626Pilot
Post by 626Pilot »
Pretty sure my E3D mount will work fine since E3Ds and J-heads use the same mount. http://www.thingiverse.com/thing:137140
Just ordered two of these and plan on buying some more.
Thanks for referring us to these!
RegB
Post by RegB »
{Not STRICTLY J-head related}
I got three of Glenn's quick connect boards just before the holiday,
along with the trick trucks upgrade. I might as well destroy everything all at once (-:
Anyhow, it turned out that on MY original hot end the cold end part isn't threaded
down far enough to allow me to use just the melamine spacer and circuit board,
I either need another spacer or a few thick washers.
Alternatively I could space it on top like Jim did, but I think that would need longer screws
and various other spacer bits.
Hmmm, I tend to over-tighten things too, tractor size wrench handling will do that to Ya.
The hardware stores seem to be closed today - ain't that odd ?
barry99705
Post by barry99705 »
RegB wrote:{Not STRICTLY J-head related}
You'd think they'd be open today. Would make a killing on the emergency batteries for toys sales.
RegB
Post by RegB »
Now TOTALLY unrelated to J heads...
A sudden discovery of head lice at my daughter's house today certainly helped the local pharmacy keep the lights on.
Tons of clothes, bedding and soft toys to wash and dry, so the laundromat made out too.
Back towards the topic; The pictures of Jim's solution are on the makerhive web site and I think I will be mounting mine
a very similar way. I am rebuilding the SeeMeCNC hot end with a pair of 20 watt cartridge heaters and the extra space
will give me a bit more space to work in. To ME this is very small work, so opening it up a little helps.
jdurand
Post by jdurand »
Dr Bronner's Peppermint liquid soap will clear those lice up. The Peppermint oil kills them.
RegB
Post by RegB »
I got three of them - a week or so ago, but time pressures have been upon me....
Since I am not a member on the makerhive I'll ask here;
{My only rationale is that I don't join anything that REQUIRES my DoB.}
{Too much other info becomes available from too many other places once that is revealed.}
Did you use multiple pins for power and ground on the big black plug ?
If so how did you do that ? i.e. the one to many split.
PS What crimp tool for the tiny pins ?
I may have to grind my radio shack crimper almost in half for the small ones, or upgrade.
It seems the ones on the strip are for the small white plugs and the 15 or so separated ones are for the big black plug.
BTW - - I HATE having to crimp things.
I've never trusted crimps with hand tools, though I acknowledge that they are in many ways the best choice when done PROPERLY, especially when done predictably by machines.
Return to “Rostock MAX v2”
