Transparent ABS T-Rex skull
Acetone Finish, or leave as is?
Finish that sucker! I wanna see a clear skull!
8
67%
No way man, that thing looks awesome as is!
4
33%
Total votes: 12
lightninjay
Post by lightninjay »
So I was inspired by Mike B to print the T-Rex skull when I saw his avatar. I was blown away when this print finished. This may be my cleanest print yet.
So, how many of you think I should attempt a cold acetone vapor finish following McSlappy's youtube tutorial here?
Or should I just leave it the way it is since it has that cool Crystal Skull look to it?
astroboy907
Re: Transparent ABS T-Rex skull
Post by astroboy907 »
I'm liking the crystal skull look ATM :)
Makes it look a bit like bone/fossil.
Flateric wrote: Black ABS, weak part, bizzare holes, bad layer adhesion, loss of details. Loss of sanity.
My Heatware!.
critical_limit
Post by critical_limit »
Do you have pics from the print?
Orientation? Supportstructure?
looks great!
barry99705
Post by barry99705 »
Vapor finish might make it clearer. Would cut down on the ridges on the outside and inside of the print.
Delta Zee Solutions
Post by Delta Zee Solutions »
Go Clear on the next one !!!
BTW, what settings did you use to print this one?
Can you cut/paste the settings from the g-code?
Thanks,
Mark
lightninjay
Hey guys! My bed was set to 90C and the hotend to 225C and the files were sliced using Cura and these settings
JasonCura.ini
Cura settings for ABS prints
(10.61 KiB) Downloaded 542 times
I printed it exactly as the stl loads from the Makerbot Academy model on thingiverse here
But here's my Gcode for the top and bottom of the skull, and here's the pic of the finished skull that came off the bed last night!
T-RexSkull_Skull.gcode
Top portion printed first
(25.01 MiB) Downloaded 618 times
T-RexSkull_Jaw.gcode
Lower portion printed second
(11.74 MiB) Downloaded 451 times
I didn't print any supports for either of the two pieces, I just made sure my printer was calibrated nice and low to my bed, sprayed the glass with "Aussie Mega Hair Spray", and away the prints went!
This is how I printed the upper skull, no supports :)
This is the way I printed the lower, also no supports.  I did slow the speed down to about 69% near the area that the jaws were beginning to connect.  The ABS was wanting to warp.
And here's the finished skull!! @_@ look at it
One crucial factor, or at least I believe it to be, is the shower curtain enclosure I made. It keeps the chamber just warm enough that it keeps warping from happening on my longer ABS prints, so I can print nice and slow to get the quality needed in this skull.
astroboy907
Have you noticed a change in accuracy (either way) with the addition of dampers, or has it pretty much stayed the same?
My Heatware!.
lightninjay
That's the sweetest part! I printed the upper without dampers, the lower with dampers, and I can't tell a difference in quality at all!
Dampers seem to have no effect on my print quality other than the sound that the motors make. It keeps the motor whine from echoing and vibrating through the entire machine.
McSlappy
Post by McSlappy »
Do it, vapor finish that bad boy!
Clear ABS tends to look pretty awesome, it kind of makes the internals more visible, so that's either a plus or a negative, but I think it looked cool :)
I know you printed the upper skull in the position shown in the picture but it sure looks like it would fall over.
Any tips on how to keep it from falling? I use hairspray but the base attached to the glass looks so small.
lightninjay
Yeah, Eagle, I have no real clue as to how it managed NOT to fall over, but apparently the guys and gals at the Makerbot Academy designed it specifically with this print orientation in mind.
I would say try calibrating your nozzle height just a smidgen lower than usual to get a nice solid stick on the first layer with the hairspray on the bed.
lightninjay wrote:Yeah, Eagle, I have no real clue as to how it managed NOT to fall over, but apparently the guys and gals at the Makerbot Academy designed it specifically with this print orientation in mind.
Thanks, all I can do is try it after a short prayer. :)
Delta Zee Solutions
Thanks for posting the G-Code lightninjay!
I'm installing the new E3D hot end as well as tossing my 50 cent trash bag curtain in favor of super clear vinyl table cover... $4.00 from the fabric store (probably the same stuff as the shower curtain). I agree that an enclosure does help with warping and more even cooling rates.
I'll try the skull right after a test print.
Mark
lightninjay
No problem guys! If it doesn't work the first time, I'd recommend slowing the print down. The top of the skull was a 12 hour print and the lower jaw was 7 hours.
craftymethod
Post by craftymethod »
Ahh.. a fellow Australian! West or East coast?
The Hair spray im using is "GARNIER FRUCTUS - ULTRA STRONG".
It does hold better than stick glue but I have had some supports knocked over and messed up. Only just build my rostock last week and working myself up to a stage I can print anything with supports just yet.
How thick do you lay the spray on? This stuff says fast drying and I give it a couple decent layers of the stuff.
oh.. how high is your first layer?
This is my latest build... No peek fan and the support for the tail failed so I think my print is a little warm, gets a bit flexxy and furry and pla seems to push up against the nozzle a bit... but here is a little horse I printed!
http://imgur.com/AXyhg6j
.25 nozzle :)
lightninjay
The spray I use is just coincidentally called Aussie, lol, here's a link to it. http://media.aussie.com/en_US/products/ ... rspray.png
I normally spray left to right and right to left in horizontal strokes across the area I need to print on. one or two passes with about half-second bursts on the spray nozzle gives me a decent coat of spray on my bed to work with.
I used the stock .5 mm nozzle that ships with the SeeMeCNC hotend, with a .35 first layer height.
predawnsky
Post by predawnsky »
awesome print Im going to try my hand a printing with clear pla soon hope it looks as good as yours
lightninjay
predawnsky wrote:awesome print Im going to try my hand a printing with clear pla soon hope it looks as good as yours
The real trick is make sure you've followed all of Geneb's instructions in the manual to a "T" in order to ensure your machine is tightly calibrated and well-maintained. :)
It also helps to follow the tips of the guys and gals on this forum that have experience with certain filament types and colors. Give it a shot with one set of bed and nozzle temps and if it doesn't come out quite right, figure out if the temps should be raised or lowered and retry! :P
predawnsky
heres my made out of clear pla
lightninjay
That's one sweet looking print! Saber-toothed tiger? I like the shiny look to it :)
Awesome print of the clear PLA skull!
Great Job.
predawnsky
lightninjay wrote:That's one sweet looking print! Saber-toothed tiger? I like the shiny look to it :)
thanks, yeah its a saber tooth tiger
predawnsky
Eaglezsoar wrote:Awesome print of the clear PLA skull!
Great Job.
thanks
