Hi everybody,
can you tell me what Travelspeed you are using with your Rostock Max / Orion printers?
I´m on 150mm/s, but due to oozing Nozzle want to go faster.
What is your experience on faster Travelspeeds?
cheers
Dirk
How much Travelspeed you are using?
critical_limit
- jeffhuber
Re: How much Travelspeed you are using?
150 is standard, but I've used as fast as 200 with no problems.
Other people would know better than me - but it sounds like what you want is retraction, not faster travel speed to reduce stringyness...
Rostock max v2 with e3d v6
- nitewatchman
250mm/sec
- Captain Starfish
600 - on a Max, though, and I'm pretty sure that the acceleration and/or firmware is limiting it to considerably less than that.
I've got mine set to 350 in Cura. As mentioned by others, I'm not sure if it's actually hitting that speed though...
