I'm new here and to 3d printing mostly
 but I'm deciding on a Delta based on what I've seen my friends' printers do and my reading on this forum among others. The Rostock V2 is top on my list so that I could learn to assemble and Mod the printer along the way. I'm trying to understand what spare parts and options might be good to order at the same time.
 but I'm deciding on a Delta based on what I've seen my friends' printers do and my reading on this forum among others. The Rostock V2 is top on my list so that I could learn to assemble and Mod the printer along the way. I'm trying to understand what spare parts and options might be good to order at the same time. One of the things our local Hacklab has is a heated bed (which the Rostock has) but are there any decent mods to keep the bed clean and parts coming off smoothly?
I've been researching how to install a dual extruder as well to print with two colors but am unsure the pros/cons on the overall machine? How hard, expensive and what hardware/software mods would i need to get from the store for a second extruder? I'm assuming Bowden tube, EZ-struder, and hot end but I don't know how hard the changes to the software and calibrations are.
Finally, what advantages to changing the nozzle to thinner/more resolution are there other then the obvious better resolution?
I should probably start with the simple build and go from there but considering our Ultimaker and PrinterBotJr in our MakerSpace lab have issues with extruder and heated bed, I know i'd like to improve these items off the bat probably in this order:
1. Heated bed improvements (plastic cover or blue tape)
2. Second nozzle and hot end plus spool holder?
3. Any other hardware and software updates for this?
