Medieval Broad Head - 0.05mm Layer
I read somewhere once that you wouldn't see much benefit from going below 0.1mm.. . . . . . I disagree!
Re: Medieval Broad Head - 0.05mm Layer
Looks good. What are you using to slice with, nozzle size? Is this PLA or ABS?
Slic3r to slice, the nozzle is the seemecnc 0.28mm and it is PLA.
I did have some interesting issues with the first and second prints - for example, I am printing it with 5 or 6 perimeters to be able to handle the super shallow angle of the broadhead and I have upped the top and bottom solid layers to the same amount. I did find with the first print that the temperature of the heated bed allowed the top face of the arrow to bubble in between the honeycomb infill pattern - no doubt due to the thin top layer.
Care to share your slic3r settings?
Pour vous.a.ash wrote:Care to share your slic3r settings?
0.05 FINE PRINT.ini
- (2.23 KiB) Downloaded 344 times
