Communicating with another Arduino over i2c
I'm looking for a way to connect the RAMBO to another arduino via the i2c connection. I'm going through the source code but can't find any good examples of opening up a simple connection and writing strings out. Does anyone know where I can find some sample code on creating some methods like this?
- Captain Starfish
Re: Communicating with another Arduino over i2c
Also known as TWI (two wire interface), supported as such under the Arduino libraries. It's a master/slave protocol so watch out for that, it's not uniformly bidirectional. Master can write whenever but the slave has to wait for an invitation before it can send data back. And I2C is very susceptible to noise - no good at all for anything longer than a few inches of separation. And don't forget pullups on the data lines - caught me out recently.
I would suggest dropping the cash on another baby Arduino and getting it talking to your new other board first. Then migrate the code into the Repetier firmware you're using to hook the two up. If you try to dev your I2C protocol within the Repetier's framework you're fighting too many battles at once, you're gonna have a bad time.
Thanks, I've already gotten two arduinos talking and have the setup complete, I'm just not sure where in the Repetier firmware to put the communication code? I see it already has a class involving i2c, but I can't find how to use it successfully. Do I just import my own library and use that instead of what's already in the firmware?
This may not be exactly what you're looking for, but give this a look https://github.com/wolfmanjm/universal-panel-adapter
- Captain Starfish
Probably not.mlapaglia wrote:Thanks, I've already gotten two arduinos talking and have the setup complete, I'm just not sure where in the Repetier firmware to put the communication code? I see it already has a class involving i2c, but I can't find how to use it successfully. Do I just import my own library and use that instead of what's already in the firmware?
Safest way would be to identify from the Atmel 2560 datasheet where the scl/sda pins are on the micro. Then find where they are already used - either as Atmel pin numbers/mnemonics, via the TWI registers (again, details in the datasheets), or as they're mapped in to Arduino DIO numbers in pins.h or whatever it is they use to map particular parts.
If you find it in use (and I remember Repetier having stuff in there for this) then try piggyback on top, otherwise you know you're safe to park your own i2c or twimaster drivers in there to play.
I am curious what the purpose of doing this is. Remote operation? Or monitoring?
Adding extra doodads.
Nozzle wiper
Leds
Heated chamber
Dehumidifier
All controlled by gCodes (MCodes).
Nozzle wiper
Leds
Heated chamber
Dehumidifier
Thanks I'll take a look tonight and see. I know there is already code for talking over i2c for the optional displays so piggy backing on it might work. I tried initializing the communication without success. I will keep trying thoughCaptain Starfish wrote:Probably not.mlapaglia wrote:Thanks, I've already gotten two arduinos talking and have the setup complete, I'm just not sure where in the Repetier firmware to put the communication code? I see it already has a class involving i2c, but I can't find how to use it successfully. Do I just import my own library and use that instead of what's already in the firmware?
I have some neopixels on hand and want to tie them in with gcode processing, different lights when certain actions happen etc. The processing for changing colors is CPU intensive and I don't want to overburden the RAMBO. I want to setup a simple communication where the RAMBO will say "hey the heat turned on" or "layer change occuring", then the second arduino can act accordingly.Mac The Knife wrote:I am curious what the purpose of doing this is. Remote operation? Or monitoring?
The SPI is used by the LCD though.
I'm messing around with the code trying to get something to output. In the printer.cpp file at the bottom of the setup method I have:
HAL::i2cStartWait(4+I2C_WRITE);
HAL::i2cWrite('a');
HAL::i2cStop();Re: Communicating with another Arduino over i2c
Ai i remember spi uses a bus for data transmission. But then an extra pin to say hey i am talking to you.
- Captain Starfish
SPI ≠ I2C/TWI
The LCD is direct drive by pin bashing, the SPI port is used to talk to the SD card. You can piggyback atop the SPI bus by adding another general purpose IO pin as a "device enable" pin for your add-ons, though, and making sure your DE is never enabled at the same time as the SD DE (aka chip select CS).
The arduinos support both and I'm pretty darned sure I had both coming off the extension connectors when I was stuffing around with thermocouple adapters earlier this year. Alas, no notes to refer to or I'd copy them straight up here.
Looking at the RAMBO schematic at the same link tells me that that there are dedicated SDA/SCL pins for the Rambo's I2C port which are not shared with the SPI or EXT headers. I also see 10K pullups on both lines.
Now whether the I2C code in the firmware is actually using those pins is a subject for further research.
When I ran a simple tutorial sketch on the rambo and another arduino device I got it to work using the dedicated i2c connector on the rambo.Eric wrote:Looking at the RAMBO schematic at the same link tells me that that there are dedicated SDA/SCL pins for the Rambo's I2C port which are not shared with the SPI or EXT headers. I also see 10K pullups on both lines.
http://arduino.cc/en/Tutorial/MasterWriter
I'm not sure how to tell what port the repetier firmware is using for i2c though.. I assumed it was the same one because the firmware can control LCD displays through it.
- Captain Starfish
Be careful with those 10k resistors. In another project I have been chasing a problem for months (on and off) whereby an OLED display sitting 2cm away from an Atmel would work for a while then fritz out. Chased all sorts of things and in the end it turned out to be too high an impedance on the pull-ups.
10k internals on the Atmel? Nope.
10k externals? Nope.
4k7 externals? Still nope (and this is the generally recommended value).
2k externals? Getting better.
1k externals? Bingo!
I'm guessing the edge detector in the OLED controller is pretty lame and needs low impedance pull ups to really haul the lines high with a nice square edge.
I seem to recall all the I2C logic being in the repetier firmware somewhere, but can't remember where it ended up either.
This is the kind of functionality I'm getting at. Right now the actions are soley controlled by the external arduino though..
https://www.youtube.com/watch?v=u4f7OIhouQg
Internal pullups are more like 35KΩ (datasheet for 2560 says min 20K, max 50K, so assume the middle). Not strong enough for general purpose I2C, so external pullups are recommended.Captain Starfish wrote:Be careful with those 10k resistors. In another project I have been chasing a problem for months (on and off) whereby an OLED display sitting 2cm away from an Atmel would work for a while then fritz out. Chased all sorts of things and in the end it turned out to be too high an impedance on the pull-ups.
For talking to another Arduino, 10K pullups should be fine.
Any progress?
Indeed! I found out over at reprap forums that the address needs a left bit shift in order to work properly. Here's the code I am using now:
Right now I'm trying to figure out how to get a float converted to a string.
When I get the serial output I only get the first digit of the X value..
HAL::i2cInit(100000L);
HAL::i2cStartWait(4 << 1);
HAL::i2cWrite('a');
HAL::i2cStop();
message += "X: ";
message += (long)code->X;
message += " ";
Aaaa,
Why would you want to trasnfer strings?
Write your own protocol that transers bytes and integers and floats. It would be much faster and efficient in my opinion.
I'm mainly a web developer with C# skills, writing my own methods for this is a bit over my head. I am trying to reuse the code already in the project. The i2cWrite method only takes in chars, so I was trying to get everything that way.
I looked at the i2cWrite method, I can't fine where the variable are being assigned or how they are actually sent over the wire:
unsigned char HAL::i2cWrite( unsigned char data )
uint8_t twst;
// send data to the previously addressed device
TWDR = data;
TWCR = (1<<TWINT) | (1<<TWEN);
// wait until transmission completed
while(!(TWCR & (1<<TWINT)));
// check value of TWI Status Register. Mask prescaler bits
return 0;
Give me a few hours to get back home.
Then i can have a look at it. I also need i2c communication.
Reading from a C# viewpoint explains your confusion. The C and C++ languages and data types predate the existence of unicode. "char" was defined as the smallest addressable unit that would contain the machines character set. These days "char" almost always means 8-bit integer; the exceptions are mostly history now. Thus "unsigned char" means an unsigned 8-bit integer, or any value from 0 to 255. In C# you would call that a "byte".mlapaglia wrote:I'm mainly a web developer with C# skills, writing my own methods for this is a bit over my head. I am trying to reuse the code already in the project. The i2cWrite method only takes in chars, so I was trying to get everything that way.
unsigned char HAL::i2cWrite( unsigned char data ) { uint8_t twst; // send data to the previously addressed device TWDR = data; TWCR = (1<<TWINT) | (1<<TWEN); // wait until transmission completed while(!(TWCR & (1<<TWINT))); // check value of TWI Status Register. Mask prescaler bits return 0; }
i2cWrite as written does not send strings, it sends a single byte. If you need more than one byte, call it more than once. The read side has to match, of course.
As for how it works: The Atmega actually has hardware TWI (aka i2c) support (http://www.atmel.com/images/doc2549.pdf, page 247 has a good diagram). TWDR is a data register. TWCR is a control register. When the hardware sees the the enabled bit has been set, it sends the byte in the data register. When the data has been successfully sent, it resets the bits in the control register to indicate it's done and ok to send another byte.
- Captain Starfish
^^ this
Where you see "unsigned char" assume "byte".
You can treat anything as a series of bytes.
For example, your float (call it fMyValue) could be sent:
Do the same on the receiving side to spoon the incoming bytes into the variables.
// in the global space, not in a function, put this:
typedef unsigned char byte; // now we can call things byte or unsigned char interchangeably.
// in your function, at sending time, put this:
byte *tempArray = (byte *)(&fMyValue); // creates a byte pointer that points at your variable
for (int i=0; i<sizeof(float); ++i) {
i2cWrite(*(tempArray+i));
Thanks guys, learning more and more every hour. teoman and I have made great progress tonight, we now have the rambo communicating with the auxilary arduino.
