Can anyone point me in the correct direction as to what setting would be causing the layers to print with these gaps? The attached pic is the bottom layer of a partially printed Octopus Fridge Magnet - printed with ABS.
My print bed consists of; copper heat dispersion plate, borosilicate plate, layer of PEI (Polyetherimide) Sheet, Opaque Off-White, Standard Tolerance, ASTM D5205 PEI0113, 0.03" Thickness adhered to the borosilicate plate with the TapeCase 468MP 0.5in X 20yd Adhesive Transfer Tape.
I am running my prints with the following characteristics; (please let me know if you need any additional information)
Software - Repetier - Host V1.0.5 with Slic3r V 1.1.7
Default Rostock hot end (although I do have a E3D V6 waiting in the wings once I can get the mounts to print correctly for attachment
SLic3r settings;
Print Settings
Layer Height = 0.2 mm
First Layer height = 0.25 mm
Fill Density = 40% Honeycomb
Top/bottom fill pattern = rectilinear
All speeds = 30 mm/s
Filament Settings
Diameter = 1.75mm
Extrusion multiplier = 1
Extruder Temp = 225
Bed Temp = 90
EEPROM Settings - see attached jpg
Thank you in advance for any help that you can provide.
George
