Adding a second layer fan to Orion
IS there any way to add a second layer fan to the Orion? Just wondering. Thanks.
Re: Adding a second layer fan to Orion
You can print another fan shroud for the layer fan: http://repables.com/r/212/deager4 wrote:IS there any way to add a second layer fan to the Orion? Just wondering. Thanks.
Click the arrow on the right of download to get just the stl.
You also will need the fan which is here: http://seemecnc.com/collections/parts-a ... blower-fan
here is the current version of the blower shroud...
Guanu
Guanu
- NEW3-Guanu-Blower-Fan-Holder-Shroud.STL
- (87.39 KiB) Downloaded 324 times
Thanks how would I wire the second fan?
The second fan is wired in parallel with the first fan.deager4 wrote:Thanks how would I wire the second fan?
Could I in theory wire three of the together without drawing too much current? Thanks.
deager4 wrote:Could I in theory wire three of the together without drawing too much current? Thanks.
Yes you can, I currently run three hooked together in parallel.
I run 3. Mainly for symmetry / even coverage.
Fans require very little power, so you're fine.
