Hello everyone.
So, my towers are a tiny bit out of square. They all "lean in" towards the middle a tiny bit. What would be the best way to adjust them? Obviously the design doesn't allow for adjustment *cough v3 cough* so how can we do it?
Shims?
Sanding?
Hammering?
My only idea is to remove the supports at the top, and shave down the part that interfaces with the top base part. Any idears?
Squaring the towers... how?
*not actually a robot
Re: Squaring the towers... how?
The idea is they should move a few degrees - enough to tighten the black things in and retain the angle you adjusted it to
- nitewatchman
Mine had enough slack to be able to pull them square and then to tighten the cap screws at the bottom to lock the towere in place.
Hmm really? I tried that at the top, but nothing changed. I will loosen them all and try. Thanks!
