If I make a change in the configuration h file and upload it will I have to do the calibration over again? Or can I export my eeprom first then import it afterward? I want to do minor changes to see their effect and then switch them back.
Updating firmware question
Re: Updating firmware question
If you're using Repetier host, yes you can save and reload the eeprom file through it and save your calibration settings.
I am not entirely sure of this but if you do not change the number of the eeprom in configuration.h the eeprom should not be changed?
