/** After x seconds of inactivity, the stepper motors are disabled.
Set to 0 to leave them enabled.
This helps cooling the Stepper motors between two print jobs.
Overridden if EEPROM activated.
#define STEPPER_INACTIVE_TIME 120
/** After x seconds of inactivity, the system will go down as far it can.
It will at least disable all stepper motors and heaters. If the board has
a power pin, it will be disabled, too.
Set value to 0 for disabled.
#define MAX_INACTIVE_TIME 0L2. Yes, that is a link to Polygonhell's firmware branch that supports the LCD Controller AND the SD card reader. I compiled it in Arduino 1.0.3 with no problems and no changes except for my specific configuration - I have a ver. 1.1 RAMBo that is 16 microsteps, not 8. This firmware's default is 8 microsteps.
