Need some help with E3D version of M3 Stud Thermistor
I got a new E3D version of M3 Stud Thermistor from ebay
http://www.ebay.com/itm/321490496841?_t ... EBIDX%3AIT
It was my understanding I set Repetier firmware to # 1
// 1 is 100k thermistor (Epcos B57560G0107F000 - RepRap-Fab.org and many other)
Even if that # is not the same
Turn on the system I get 500 C then DEF
Anyone use this model? what setting did you use?
Thanks...
DarrenAnton
Re: E3D version of M3 Stud Thermistor
Yes, you have the thermistor setting correct. It sounds like you might have a short. I'd remove the thermistor from the hotness and test it unattached. You an hold it between your fingers to get some temperature rise.
