Hey guys,
I have been printing in PLA most recently and I am really happy with the results. The only problem I really noticed was the side opposite of my layer fan isn't as clean as the side with the cooling fan. Surely this is do to than fan only blowing from one side. What are you guys doing to combat this problem? I don't want to buy more squirrel fans and print more shrouds because I feel that would make my hotend gigantic. And doesn't it reduce my effective build area if I do it that way/
I wanted to make something like this: http://www.thingiverse.com/thing:43983 so that I could use one fan and get even cooling, but it's designed for a 40mm fan, not a blower. So I tried to "fuse" design aspects of SeeMeCNC's layer fan shroud with this annular shroud so I would have the fitting for the blower and the annular shroud part, but I am not very skilled in 3DS Max.
So what's the best solution?
QT
How do you guys handle uneven cooling?
QuantumTitan
- Plasticator
precisionpete
Re: How do you guys handle uneven cooling?
Maybe not the best solution but it works great.
I have one of those small desk fans maybe 4" diameter. Point that at the bed ~ 8" away on low setting.
worked for me
worked for me
I bought two more blower fans from SeeMeCNC, printed two more shrouds and installed them on the remaining two tabs on the effector plate.
Here is a fan shroud I designed for 360 deg cooling.http://repables.com/r/436
QuantumTitan
- Plasticator
Yeah, that's similar to what I was trying to do but it wasn't going so well. Thanks a lot, I'll give it a go.JFettig wrote:Here is a fan shroud I designed for 360 deg cooling.http://repables.com/r/436
dunginhawk
I took mac the knifes advice and did the same. I run three layer fans with guanus newest design... I dont have uneven cooling at all... works fantastic
