Not sure if anyone else has seen this or tried it, but I had ordered 125g spool of it on their pre-order page to try it out and it came it last week.
The results are pretty nice, the material has a lot more weight to it then standard filament and the finish looks pretty sweet once it's polished. I will say the filament seems a bit temperamental, mainly with trying to extrude it, I've found I have to print really slowly or the extruder starts slipping, I also had better luck printing at a higher temp, they recommended 215, I've been printing at 225, I used their recommended 50C bed temp and used purple elmers glue stick on it, had no problems at all with bed adhesion. I do need to figure out what's up with my printer though as my infill keeps having small gaps from the perimeter, I hadn't noticed that with any of my ABS parts, but most of what i've been printing lately doesn't have a smooth top surface like that so it could be it's having that issue and I haven't noticed it because of what I've been printing.
Anyways here's two things I've printed with it so far, this one is a pendant with the S.H.I.E.L.D. emblem from the Marvel movies/agent's of S.H.I.E.L.D. tv show.
This one is a pair Wonder Woman earrings, the top one is after polishing, the bottom one is what the print looks like straight off the printer. These were printed on a V1 Rostock MAX with an E3D v6 hotend with a .4mm nozzle.
Proto-pasta stainless steel filament
Re: Proto-pasta stainless steel filament
That is crazy cool!
McSlappy
Awesome, love the effect!
BenTheRighteous
Wow, what a difference polishing made! Very cool!
Hows the part strength? I'm not expecting it to hold up like real steel, but is it excessively fragile?
It's definitely not fragile by any means, however it is weaker than ABS, I know the plastic they use in it is PLA, however I've never printed with PLA so I can't give a comparison to straight PLA, I had a ring I had printed with a 2mm thick wall, 8mm wide, I was able to break it but it took a decent amount of force to do so, I would assume it's somewhat weaker than straight PLA since it has the stainless powder in it. I will note though that in filament form it's pretty brittle so you do have to be careful then, I managed to snap the filament once trying to push it thru the extruder.
