Hate to ask, but im away from my printer and computer and this is bugging me.
How do i lower the minimum extruder temperature from its current 150C to about 130C? Is this stored in configuration H, or can it be set from the lcd? I need to try lowering it for this new filament. Help!!
how do i lower extruder min temp?
Lost pla castings? see me
Earthbound
Re: how do i lower extruder min temp?
The value is initially set in Configuration.h. Very near the end of the file, only a few lines from the bottom:
#define UI_SET_MIN_EXTRUDER_TEMP 150
I am away from my printer to verify, but based on the naming of the variable, I am guessing it can be adjusted via the LCD, but would revert to the Configuration.h value on reset or power cycling.
