I just thought of something when tweaking the calibration of my rostock: Why do we need to adjust the endstops? Why not just change the maximum height and then keep measuring until it's "flat" from the center to the 3 edges. Once the endstops are parallel to the bed, i think it might be counter-productive to keep tweaking them.
Anyone know why it's written the way it is?
Horizontal radius calibration
Rostock Max V2 with mods:
E3d v6 with 713maker mount & e3d titan extruder
Tricklaser CF arms, heat spreader, tricktrucks, fly-n-strude, metal carriage & effector
Duet v.8.5.0
24v MeanWell 750w PS & Cydom D1D40 SSR in parallel with stock 12v PS
Duet v.8.5.0
Re: Horizontal radius calibration
This link is the way most/some? are doing it now. Maybe I'm not tracking what you're asking this early in the morning.
http://forum.seemecnc.com/viewtopic.php?f=77&t=5906
Great question.
I had a process down that took me 5-10 minutes to get my towers adjusted. It required a dial indicator and a final tweak of the horizontal radius. I could get things within .001" from center to all 3 towers.
What got me fed up with it all is that I had to do this often...about every 3 weeks. It would be off as much as .01" or more between towers. Why do you suppose that happened? I never figured it out. I just knew what I had to do to correct it temporarily.
heathenx wrote:Great question.
I blame humidity fluctuations.
KAS wrote:This link is the way most/some? are doing it now. Maybe I'm not tracking what you're asking this early in the morning.
Oh. I was referring to the geneb instruction manual. The flow chart in particular.
Duet v.8.5.0
Duet v.8.5.0
