Hi everyone,
My X tower is about 3mm too low (nozzle hitting the glass) and the screw is tightened as far as it can go. I've tried to change the X tower offset in the EEPROM as well as in the Configuration.h file and there is zero effect in the positive & negative directions.
Has anyone else had this problem and found a fix?
Thank you!
Aaron
Tower offsets not working at all
HoosierCruz
- Plasticator
Re: Tower offsets not working at all
Mine refused to get negative values as far as i can remember.
It did work for me.
I would set all the screws to mid level and start again.
It did work for me.
HoosierCruz
- Plasticator
Thanks for that advice! Yeah now I can't even send a clear EEPROM command to the arduino - "failed miserably to execute command 0x1d"
I think I have bigger problems...
Do uou have the correct board selected?
That one gets me all the time.
Tower offsets work great for me, using all negative numbers. I used to be a proponent of screw adjustments only, but I've since learned the error of my former ways.
*not actually a robot
