Hey so this maybe a silly question but I'm not sure how to get my prints to the SD card. I have tried to load it from the queue but that doesn't seem to work. Also I have tried to export the print to the SD card but I have not had any luck with that either... Not sure what to do. I have been using the cable to print stuff now, but when my computer shuts off from not being used for so long it stops the print.
Ziggey
SD card
Re: SD card
Export as gcode, then copy the gcode to the sd card. when you put the card in the machine, select the gcode file and it will run
Re: SD card
Ok I will try that Thank you.
Ziggey
Ziggey
