Noob Question
Gundy1024
Noob Question
Post by Gundy1024 »
So I have what may be a stupid question but I can't seem to find the answer here so far. In matter control it shows my bed size as 150mm which equates to 5.9 inches. Should I have this set to 279mm being 11 inches? I notice that when I make prints they end up taking up a lot less space than matter control is showing they will which has kept me from trying bigger prints. Sorry for the noob question.
Gundy
Rostock Max V2 - Unnamed as of yet...
Robo 3D R1
One of the two printers can be found streaming at the link below just about every day. :)
https://www.youtube.com/watch?v=wky8RuNW9TY
TFMike
Re: Noob Question
Post by TFMike »
yes, and I would back off using matter control as well lol
Gundy1024
Re: Noob Question
Post by Gundy1024 »
What would you suggest? I have repetier but have no clue how to set it up.
Robo 3D R1
Tincho85
Re: Noob Question
Post by Tincho85 »
I tried to use MC, but the way it rotates the model is awful.
That made me uninstall it :P
Here, Repetier-Host Edition:
https://mega.nz/#!NZJiHQZC!zK-WtJlp_-Pp ... QEOpmJ_FMA
Martín S.
cyber.shifter
Re: Noob Question
Post by cyber.shifter »
Tincho85 wrote:I tried to use MC, but the way it rotates the model is awful.
I've seen mention of using Repetier-Host in a couple places now, outside of these forums. I am hesitant to switch control programs, but I do get frustrated with MC. How easy is it to convert to using Repetier-Host, since I am still fairly new to the game? Tincho85 I'm pinging you on this, since you seem to have had the same thoughts and then made the switch.
--nil volentibus arduum
bot
Re: Noob Question
Post by bot »
The old version of the assembly manual details the way to set up Rep Host. I'll attach it here.
Rostock-MAX-v2-Assembly-GuideRepHostInst.pdf
(226.81 KiB) Downloaded 249 times
*not actually a robot
Tincho85
Re: Noob Question
Post by Tincho85 »
Oh no.. I never actually used MC. I tried to, but quit once I rotated a model.
If you have the time, give it a try. The link from Mega.nz is the complete guide with Repetier-Host.
Martín S.
bot
Re: Noob Question
Post by bot »
Oh oops. I didn't realize your link was also for the manual.
