LCD panel issues
LCD panel issues
I finally got around to plugging in my LCD screen on my rostock max v1 this weekend and am having some major problems. I made sure the cables are plugged into the correct spots but when I turn my machine on the LCD does not light up at all and my machine starts homing about every 5 seconds. The log in repetier says it keeps resetting the machine. I am using the shorter cables and have triple checked they are plugged in correctly. any thoughts?
Earthbound
Re: LCD panel issues
Pictures would help. I'm not familiar with any connection differences on a v1, but the most common problem other than swapped cables is plugging them in backwards. Color stripe on cable belongs on pin1 end of header.
Interesting. It sounds like mine may be backwards, however due to the shape of the connector they only plug into the LCD one way. I will attach a picture.
Earthbound
How about a shot of the other end of those cables, too.
other side was flipped. LCD now working fine. :/ sorry to waste your time. Thanks for helping though! I appreciate it!
You did not waste anyone's time. All questions have value because other users read them and learn from them.dylantep wrote:other side was flipped. LCD now working fine. :/ sorry to waste your time. Thanks for helping though! I appreciate it!
Please submit any question you have, that is one of the reasons this forum exists.
