Print shifting consistently
ericpudding
For every print lately I have had consistent shifts about an hour in. I have tried many different options but still have shifts. I tried tightening the belts and making sure the carriages were correctly tightened. After that didnt work, I thought the Rambo board was too hot and I have a desk fan aimed directly at it but still get shifts. I have also lowered the print and move acceleration. I have run out of ideas of what to do to fix it. Anybody have other ideas?
BenTheRighteous
Re: Print shifting consistently
same model every time?
ericpudding
Yes. But I slice it again every time. And I have printed it successfully before with the same part file.BenTheRighteous wrote:same model every time?
BenTheRighteous
Without having any idea what the model looks like, I'm guessing your travel move is too high.
If your model gets out to the edge of your print area, you've got to be careful with the speed of your travel move. Try lowering that a bit.
I think greasing my joints solved the problem.
I wonder if that would work with my arthritic joints?teoman wrote:I think greasing my joints solved the problem.
Could do,
Take them apart and pump in some teflon
No, use bacon grease. Bacon fixes everything.
- barry99705
- barry99705
Seeing Wolverine do it is just funny though! Aww, you didn't post the 12 hour version!!
