Hello
I built a bit size printer. rod length of 60cm
what are the changes in the eeprom that I need to make? and what are the clibration values of the scriptes?
thanks
Big size printer - help needed
Re: Big size printer - help needed
does it have the same bed? same tower distance? same effector? same carriages?
Hi, thanks for the help.
the bed size is 120 cm ( 60 radius ) the arms lenth is 600 cm and the max hight is 1.2 meter.
the effector and carriages are the same.
What? 6m arms?
I am sure you have all of us intrigued, mind posting a few pictures?
You would defintely have to go over the software. Are you using a RAMBO?
Yea, I would think your max height should be a bit taller to match those arms.
I think it's 600mm, which is still huge... so I'd love to see pics.
*not actually a robot
hi
it was ment to be 600 mm ( 60 cm )
I am starting to calibrate it.
any changes in eeprom?
i will upload pics later
Yes there will be changes in the software AND the eeprom.
Arm length, and bed diameter for one. What effector platfomr are you using? That also has an effect on the bed size. Bubbasnow has previously done something similar.
arm length changed.
where is thr bed diameter?
stock effector platform
