I have a question :
i have already calibrate de DELTA_DIAGONAL_ROD on my Bootsindustries delta printer and the size on the X and Y axis is correct , but when a measure a print on the height (z axis ) it doesn't fit to the actual size to the print:
what comand on the EEPROM firmare should i to ajust if i want to change this value ?
what i understand is that not make sense if a change the Layer Height on the Slicer manager because is a fail from the printer configuration ,and the horizontl radius can just set the print flatness.
thanks
Size Calibration - DELTA_DIAGONAL_ROD
Re: Size Calibration - DELTA_DIAGONAL_ROD
The only thing that affects the height of a print is the steps per mm which should be calculated from the belt pitch and the pulley teeth along with the Stepper type and uStepping setting in the firmware.
If you change it it will affect scale in all of the dimensions.
IMBoring25
...And if it's a stock v2 running the stock firmware, that should have been right from the beginning. How far off is it?
He states in his first post it isn't a Max, some other delta printer.IMBoring25 wrote:...And if it's a stock v2 running the stock firmware, that should have been right from the beginning. How far off is it?
IMBoring25
Oops, read right past that.
