Rostock Max v2 Delta Arms issue
PJJ
Post by PJJ »
whats up everyone I'm new to this forum and just recently bought my new rostock 3d printer. Well i finally have finished setting it up (took about two weeks) and begin to turn it on and configure it and thats where my problems occured. I am trying to configure the printer to end up creating my first print. However upon trying to i try to get the rostock delta arms to move and when i hit the home button on the software nothing moves. the arms never move not even a inch. Also the heating bed cuts on and gets to the temperature i set it (55C) but the extruder does not get to the temperature i set (200C). I was wondering if anybody has ever heard or have had experience with this issue before. The software I am using is repetier host however i did try matter control first like the documentation said and that also didnt work. I really want to start printing lol PLEASE HELP!!!!!!
teoman
Re: Rostock Max v2 Delta Arms issue
Post by teoman »
Does the lcd panel work? Can you adjust the z height or home?
Have you done the endstops properly?
PJJ
Post by PJJ »
the lcd panel works when i press home on the repetier host it does nothing and the endstops are properly installed i even did the "M119" and the heights all come up as "L"
PJJ
Post by PJJ »
teoman wrote:Does the lcd panel work? Can you adjust the z height or home?
however i did have to change computers so at first when installing the maching it was com10 but when my first computer wasnt powerful enough to run the software i switched machines and now it came up com6 however I did reinstall everything. does that matter
teoman
Post by teoman »
That should not matter.
PJJ
Post by PJJ »
teoman wrote:That should not matter.
ok so i had bad fuses on my board so i replaced them however i still can not get the arms to move
Earthbound
Post by Earthbound »
And is the RAMBo cooling fan running?
KAS
Post by KAS »
Can you please take a picture of the RAMBo and the endstops?
Also when you said the M119 command shows L, was that with or without you holding each switch closed with your finger? Just trying to get an idea if the switches are wired for NC or NO. (Also make sure each cheap-skate is pulled away from the switches when running M119)
PJJ
Post by PJJ »
KAS wrote:Can you please take a picture of the RAMBo and the endstops?
attached is a few pictures of the rambo and endstops. Also when i m119 shows L, it is without holding the switch with my fingers. They change to H when i hold them.
seemecnc.docx
(26.35 MiB) Downloaded 234 times
