Prints over 10% over scale??
Potatohead908
I am just starting printing with my Max V2. The first print was for the PEEK fan as per the instructions. The print is over-sized by about 18%. The fan pocket measures 29.4mm by 29mm tall. What are some of the things I may have done wrong?
Potatohead908
Re: Prints over 10% over scale??
My thinking is that it is the steps per mm in the settings? Or that there is a scale factor but I can't find that.
Potatohead908
Ok I used a block to see what the MAX thinks it moved compared to what it actually move. It is the steps per MM. So I looked into the configurator and found that I adjusted the wrong setting for the extruder feed rate. No I have to find the correct number for the steps!
Last edited by Potatohead908 on Sat Aug 01, 2015 2:33 pm, edited 2 times in total.
Potatohead908
Looking for the proper number now for steps per mm
Potatohead908
Now for the next question. Should I need to re-calibrate the axis to re-acquire the Horizontal radius number?
Yes, you should recalibrate everything to be sure. Banging the end effector around repetitively is not really good for it.
I had also had the problem where the parts were %10 too large, i restarted by flashing the firmware and continuing from that point on in the manual and it solved the problem. I have no idea what the cause was.
Have a look at this thread for calibration, it has helped my calibration immensely. Also at tome point, my printer lost the values in the EEPROM, and thanks to the excell file, I was able to restore them with ease.
http://forum.seemecnc.com/viewtopic.php?f=77&t=5906
Potatohead908
Ok I've recalibrated it now. I was able to print the fan mounts without doing the recalibration though. Just an FYI.
Thank you.
Thank you.
