New Layer Fan design.
KAS
Post by KAS »
Just a quick & simple layer fan mount I'm trying. Looking for a solution that wouldn't interfere JFettig's enclosure. Inspiration came from the ATOM 2.0.
[img]http://i482.photobucket.com/albums/rr18 ... 133105.jpg[/img]
[img]http://i482.photobucket.com/albums/rr18 ... 133233.jpg[/img]
Panasonic Fan: http://www.mpja.com/5VDC-Mini-CPU-Fan/p ... 2166%20FN/
Fan Mount STL: http://repables.com/r/598#
Re: New Layer Fan design.
Looks great! I've been thinking about something similar, but I might just like your design better :)
Why 5v though?
KAS
Post by KAS »
I haven't found a 12v version. I've been running one at 12v for about 3 weeks with no issues. That said, I have no idea on reliability.
With the 3 fans, I've been running it as 50% which is measuring 6v on the meter.
Tincho85
Post by Tincho85 »
Oh symmetry, my karma.
I love it :D
Martín S.
Nice find on the fan but I have a question on the mounting.
It looks like you are using zip ties to hold the fans, is this correct?
KAS
Post by KAS »
Eaglezsoar wrote:Nice find on the fan but I have a question on the mounting.
I guess that picture is deceiving. I used the zip ties to hold the wire from the fan out of the way. Each mount is held in place with a 1/2" screw through the top of the effector.
KAS wrote:Inspiration came from the ATOM 2.0.
That's purdy.
[img]http://www.atom3dp.com/wp-content/uploa ... 30x579.jpg[/img]
KAS
Post by KAS »
It sure is, just wish I could figure out a way to match it with our current effector.
Thanks for the better picture clearly showing the screws holding the mounts.
Very nice!
AlphaLima
Post by AlphaLima »
Love it! Also run that enclosure and have just been installing the fan and then shrinking my bed in the slicer to make sure i dont collide with the walls. Will need to look into ordering these fans.
ramai
Post by ramai »
I'm gonna try this out. I'll need to modify it for the fans from seemecnc though, since I picked up 2 more of those. (wished I would have known about these panasonic ones for 4 bucks!) Quick question about your wiring. Did you solder them all to the same layer fan wire?
Cura slicer, Duet Wifi, iMac
ramai
Post by ramai »
Actually KAS, before I dive in too deep with this, how amazing has it been having triple cooling action?
ramai
Post by ramai »
I went ahead and modified the file to fit the stock 30mm blower from Seeme. Here is the file in case anyone wants to give it a go. It's a nice fit.
fan mount for seemecnc layer fan.stl
(283.42 KiB) Downloaded 237 times
KAS
Post by KAS »
I didn't have much printing time on the setup above as I switched my effector to the metal one at trick laser. I have to redesign the mount to match the different tabs on that effector.
50% on the fan speed gives the +6v to the fan although I've been running one at +12v for a few weeks without issue. Three fans at +12v is a crazy amount of air, if you have the angle off a tad you can over-cool the hotend and never reach printing temps.
Tincho85
Post by Tincho85 »
Hey KAS, I finally bought some. Got them used from a local store.
They are surprisingly quiet, I thought they will be louder.
Thinkpad 380 series laptops use them as a cooler. All 3 of them look the same but they are slightly different.
They are 35x35x6mm aprox
[img]https://c2.staticflickr.com/2/1599/2442 ... 4247_o.jpg[/img]
1º) UDQFC309 - 0.15A - 6X01
2º) UDQFC3E11 - 0.15A - 7217
3º) UDQFC3E14 - 0.09A - 7X29
They do sell them as the same item. I tested them and seem to have very similar air flows.
[img]https://c2.staticflickr.com/2/1657/2503 ... 252c_o.jpg[/img]
That's all for now, If I do install them I will keep you guys posted.
Martín S.
Glacian22
Post by Glacian22 »
I am REALLY excited that you posted this...I just bought a couple of those fans, and also have a prometheus mounted under my effector. Printing them out first thing in the morning!
Renha
Post by Renha »
Wow! Love that!
3D printing is magic!
