The other problem is the extruder won't heat up. I checked the wires for continuity and I am plugged in to extruder 0 on the rambo and the bed heat works so I don't think it's the mosfet fuse....
HELP!!!!! (please)
Heated bed is connected to a completely separate 12V line and independently fused.bplemmons wrote:I'm trying to calibrate my rostock but I'm stumped on 2 issues. The print head zeroes out 2 inches above the plate. the instructions say to change the z home pos. by increments of 10 but i must not be on the right setting because nothing I have tried will bring in down anymore than 2' too high.
HELP!!!!! (please)
if your fuse blew, you need to check for shorts also.bplemmons wrote:Looks like it is the fuse, got one on order....
Thanks again for your time
