Hello-
I am using a Mac instead of a PC and I followed the instructions for downloading Arduino and no options for "com" come up for available ports. I have /dev/cu.Bluetooth-Incoming-Port, /dev/cu.Bluetooth-Modem, and /dev/cu.usbmodemfa131 available. Any ideas?
Using a Mac...not PC
Re: Using a Mac...not PC
Unplug arduino,
Check ports,
Plug arduino,
Check ports.
It is the one that appeared.
Check ports,
Plug arduino,
Check ports.
It will appear similar to those you listed. They are not called com on the mac.
- Captain Starfish
Probably that last one.
- unplug the connection.
- Start the Terminal app.
- type
- plug the connection in and give it a moment to get discovered etc by the computer.
- type
then
You should get something like
These are the two endpoints for the usb serial connection. I tend to go with the "cu" version but I think both work OK.
Don't forget to clean up the files:
- type
ls /dev > t1- type
ls /dev > t2Code: Select all
diff t1 t2Code: Select all
17a18
> cu.usbmodemfd131
192a194
> tty.usbmodemfd131Don't forget to clean up the files:
rm t1 t2
