Well after weeks of researching, designing and general Googling.... we are off!
Ordered all the follwoing parts, and looking forward to many evenings of rewarding 3d printing (or pulling out my hair and swearing a lot)
RoStock Max v2 kit
E3d V6 hotend
Replacement 750w Corsair PSU
Copper RTV Silicon
Trick laser 300mm carbon fibre arms
Trick laser Nema stepper motor dampers
Trick laser J-Head groove mount for the E3d V6 hot end) - hey it was on offer, what the heck
Extended screws for the E3d V6 hotend
Silica packs for the filament storage
Kapton tape
Replacement 40mm Noctua fan
Replacement 25mm bearingless fan (just in case)
Roll of PLA
Roll of ABS
Sheet of PEI for the hotbed
RGB led ring for the print head
RGB led controller
I ordered the upgrades straight away, because I know I an upgrading the hot end anyway.... so lets do it now. Plus... impatient like that!
I have designed a cabinet with full enclosure and heating. I will start on that once I have the main unit assmebled and had a little play.
First job..... paint those edges on the printer panels!
I was going to keep a photo log of the entire build. I have found other peoples build logs interesting, so why not.
Got an old laptop out of the workshop and I plan to add that to the printer workstation.
Fun times!
I have a question regarding the hotbed. I have read multiple threads about people having issues with the connection to the Rambo. Basically.... it melts.
What is the output from the Rambo? Surely its basically 12v on and off as required - depending on the thermistor.
I was thinking of using the Rambo output to operate a 40A relay and wiring the hotbed through that instead. Possibly in 10 AWG cable or something.
