I was 2+ hours into a big print and the machine cut out--literally, like it died. I filpped the ON/OFF switch off, then back on and Viola, it fired up. I had had a box around EVERYTHING--including the base--which turned out to be kinda dumb. It overheated.
So, I built this:
Only one side of the new cooling box is open--opposite the fan.
I removed all covers for the base for optimum airflow in and around all components.
The heatbox has a fourth wall to use while printing.
Cooling overkill?? Nope.
scooter it.
Re: Cooling overkill?? Nope.
That's a sweet vintage fan, nice!
You've got to steampunk out the rest of the build now!
The fan is from a space heater with a bad heater element. Perfectomundo for this application.
"You've got to steampunk out the rest of the build now!" --not sure what this means.
scooter it.
- lightninjay
As per Googling steampunk, the wiki definition:GPriv wrote:The fan is from a space heater with a bad heater element. Perfectomundo for this application.
Steampunk refers to a subgenre of science fiction and sometimes fantasy that incorporates technology and aesthetic designs inspired by 19th-century industrial steam-powered machinery.
lol...
Maybe after i print out what i really am working toward i will design a fancy/crazy shroud...
scooter it.
Vintage themed mech-tech, essentially.
[img]https://cdn.shopify.com/s/files/1/0224/ ... 0.jpg?1841[/img]
Sorry to hijack your thread... There's some good stuff out there
I'm done after this one, I swear.
[img]https://static.squarespace.com/static/5 ... 779f_z.jpg[/img]
[img]http://blogs-images.forbes.com/erikkain ... ampunk.jpg[/img]
I might need that stormtrooper in my life. I might need it bad.
wow nice work!!!!
Self designed plasma cutting table running Mach3
Orbot Hadron running and E3d 6, Smoothie on an Azteeg Mini, LCD, fully adjustable glass bed of my design with a silicone mat heater.
Prtrbot Simple Metal
Table top CNC running Mach 3
