Hi all,
I need some help.
I started a relatively big print and after the 6 or 7 layers I can see that I have a small shift in the print. The shifting it towards it front.
What do you think than can cause me to take there%y
A small shift while printing
Re: A small shift while printing
Have you checked your belts to make sure that they are snug and are not rubbing on the sides of the upper bearings?
if its shifting toward the front, it sounds like you can narrow it down to your Z-axis. make sure everything is tight and moving smoothly.
