I could buy this item? It is the power in header on the side of the RamBo. It looks like it got a little toasty.
Thanks
Tony
Does anyone know where...
Re: Does anyone know where...
I'd email Ultimachine about it - if nothing else they can get you a part number you can use to order it from Mouser.
You can also send the card to Ultimachine for repair and the costs would be reasonable.
Thanks, the card is fine . Ultimachine has the header available on thier website. Wish I could find a supplier in Canada.
gchristopher
There's a BOM for the RAMBo on their github. I've replaced components on it (in Alaska) and they're all on Digikey/Mouser/etc, so shipping to Canada shouldn't be bad.
RAMBo github
The schematic pdf lists that as part MSTBA6, the BOM says that's: "6 pin fixed terminal block;Molex;39532-1006"
Mouser and Digikey both helpfully list the appropriate mating connector.
http://www.mouser.com/Search/ProductDet ... XWUw%3d%3d
http://www.digikey.com/product-detail/e ... ND/1280673
I'd double check to make sure that these are the correct parts, but looks like if that's all you fried, it'll be a cheap fix!
RAMBo github
Wow, thanks for your effort in looking this up. I see digikey.ca has what I am looking for.
Thanks again!
Thanks again!
gchristopher
No problem. Thanks should go to Ultimaker for nicely documenting their work online.
Good luck with the repair!
