Hi,
I just got time to start building my kit, and I've gotten to the "jump to pt 17 and install the idler bearings" part. Problem is, I can't tell how to install them.
in the picture it looks as though the bearings are installed on the motor mount and tri-support? One and then the other in a straight line.
The holes in my motor mount-tri-support don't seem to match. There aren't any in a straight line. Are there any other pictures available? Maybe one from the top (without the top plate attached)? Thanks.
-sandy
idler bearing placement question
Re: idler bearing placement question
the bearings are not lined up with each other they are slightly off, back one is higher than the other. this what u meant?
that does help. I was afraid that I'd put the supports together wrong. Thanks.
- MorbidSlowBurn
I know cambo3d already helped but here is another shot from an acrylic rostock so you can see it from the side.
[img]http://i1299.photobucket.com/albums/ag6 ... e00bad.jpg[/img]
thanks for the pic. That is how mine looks. And, it also helps me see how the belts should go. I'll be doing those this weekend.
best,
-sandy
best,
-sandy
