Calibrating Rostock Max Ver2 w/Tricklaser Metal Max 300mm
cpu77
Post by cpu77 »
I have recently finished my Rostock Max Ver2 with the following mods.....
1. Tricklaser MAX METAL Platform
2. Tricklaser Trick Trucks
3. Tricklaser Heat Spreader
4. Tricklaser 300mm Carbon Fiber Arms
5. Tricklaser Stepper Motor Insulators
6. Prometheus v2 All Metal Hot End
My Z Height is 345mm using paper test. HE Calibrated and up to temperature.
Does anyone have some base values for the tricklaser setup for.....
Diagonal Rod Length:
Horizontal Radius Length:
Thanks in advance Ralph
Re: Calibrating Rostock Max Ver2 w/Tricklaser Metal Max 300m
Your diagonal rod length is...300mm. :)
cpu77
Post by cpu77 »
LOL Thanks. I thought that might be the case but got confused by some other stuff I read online.
cpu77
Post by cpu77 »
After doing some searching I measured and came up with 132mm. Does sound right?
