Hello
I have a heatlamp to heat the air temo when printing ABS ans so...
I want to assign a pin from the board to the SSR that when in start to print i will a commang in the gcode to get that pin to high so the ssr will turn on the lamp and add a code to the end gcode to turn it of.
Is there a free pin for mr to use? and how can I use it?
thanks
Rambo board pin to control SSR
Re: Rambo board pin to control SSR
There are free pins to use. My suggestion is to use the case light. Discussion on finding it and using it can be found here:
http://forum.seemecnc.com/viewtopic.php ... ght#p80955
thanks but I am using .91 software
There is GCODE to switch the pins on and off. You just have to find the pin.
