Rostock max v1
mcdarren23
Rostock max v1
Post by mcdarren23 »
Hi all, I'm new at this and I am from the uk. Having problems with a v1 I have bought. The LCD screen just stats blank And read back is telling me the bed is 700 degrees. Also does anyone have the full settings for the v1 Thank you for your time
mcdarren23
Re: Rostock max v1
hi all. having various problems.
i have installed the rambo driver and it doesnt do anything.
i have the matter control and that will not connect to the printer.
the printer is on a port as i have installed driver wear etc.
repetier allows me to connect but lists no start sign, force start
also on my devices page it just lists one device (printer) no rambo ? is this correct ?
thanks
Re: Rostock max v1
Hello, sounds like we need to start form the beginning! How long have you had the V1? Was it working properly at some point and now not working?
Next, what operating system are you using on your computer that needs the driver (it makes a difference)?
Next, it might not be the driver but simply the communications configuration in MatterControl to talk to the RAMBo - baud rate primarily.
I'm primarily a Macintosh guy but I do have a windows 10 laptop I can use to check.
mcdarren23
Re: Rostock max v1
i have only had it a week, i was told it was in working order but im not so sure.
the operating system i have is windows 7 prob 64 bit
in my device manager the printer comes up as 3d printer powered by ramob (ports) and thats all there is
thanks
Re: Rostock max v1
Did you see it working? It could be as simple as communication config.
Ok, lets start with Repetier Host as I am most familiar with it.
Under the Printer menu, choose Printer Configuration and either screen shot or reply with he Communication parameters listed there.
mcdarren23
Re: Rostock max v1
config : printer settings
and printer : printer information
Nylocke
Re: Rostock max v1
Post by Nylocke »
It seems you have a really old version of Marlin or something. This seems likely since it is a V1 and they shipped those with Marlin at the time. You'll have to upgrade the firmware to a newer version of Repetier most likely. Can you post some pictures of the machine so we can see if there are any mods that might need to be accounted for in the firmware config?
Re: Rostock max v1
Ok, we need to see what's on the Connection tab please.
Re: Rostock max v1
Nylocke, seriously, Marlin? I have a pretty early V1 and it had Repetier. First I've heard of Marlin!
Nylocke
Re: Rostock max v1
Post by Nylocke »
The only V1 I ever laid hands on had Marlin. It had marlin until I upgraded it this summer to .92 repetier. It worked pretty well actually, not jittery like 2014-2015 marlin.
I'm thinking its that because the printer isn't communicating firmware version or following standard port opening protocol with newer versions of repetier. I might be mistaken though.
mcdarren23
Re: Rostock max v1
connection tab :
thanks
Re: Rostock max v1
Ok, so first up is we need to see if we can get Repetier to connect. Is COM14 the port that shows up in the windows device manager? If not, change that and attempt to connect first - you do have to click the Connect button at the upper left of the Repetier screen. Hopefully you know that
Try it and let us know how it goes then we'll go from there.
Re: Rostock max v1
Ok, I checked with John and he thinks that maybe early early early on there were a few Maxes that had Marlin. He didn't say if these were sold. It would be odd that one would make it to the UK!
Nylocke
Re: Rostock max v1
Post by Nylocke »
The one I got back in 2013 to work on at work had Marlin on it. It was in the manual that Gene made. I guess I assumed everyone used the same manual. Both rev 1 and 2 I think were like this. It has been a while since I've looked.
Re: Rostock max v1
If that's the case mcdarren23, then RUN and install Repetier! That will also help with the connection debugging since you'll have to setup the connection in Arduino to upload the new firmware.
We'll have to track down a version for you to use though. The early Maxes had 16 tooth as opposed to 20 tooth pulleys. Mine has the 16 tooth pulleys but i don't run RAMBo any longer.
Re: Rostock max v1
An acrylic machines tells me "IndieGoGo" machine. He's probably got the custom cut 15 tooth gears on it too.
Re: Rostock max v1
I'm not sure why we think he has an acrylic machine or even Marlin? I don't see anything in the OP that indicates this and he screenshots aren't definitive since he hasn't been able to connect yet. Just asking...
Re: Rostock max v1
geneb wrote:An acrylic machines tells me "IndieGoGo" machine. He's probably got the custom cut 15 tooth gears on it too.
There was a brief period of time outside the IndieGoGo that they were selling the acrylic machines and it was the very first machine I had.
Still have pieces of it around somewhere. I do remember the 15 tooth cog and it is best to count the number of teeth on the cog several
times to make sure how many teeth the user's machine has. The old acrylic machine basically "cracked up" which I think it got from me.
Re: Rostock max v1
@Eagle, I remember those acrylic machines!
Windshadow
Re: Rostock max v1
Post by Windshadow »
mhackney wrote:I'm not sure why we think he has an acrylic machine or even Marlin? I don't see anything in the OP that indicates this and he screenshots aren't definitive since he hasn't been able to connect yet. Just asking...
He started with a thread in the V1 forum that did not get a lot of attention
Re: Hi all from the uk, I have a rostock max v1 acrylic
Postby mcdarren23 » Mon Apr 25, 2016 10:37 am
Re: Rostock max v1
Ah, thanks Windshadow. I missed that one.
mcdarren23
Re: Rostock max v1
Pic of printer.
Nylocke
Re: Rostock max v1
Post by Nylocke »
That is classic. RAMPS, the Steves extruder and an earlier SMC hotend.
Re: Rostock max v1
mcdarren23 wrote:Pic of printer.
Your picture brings back a lot on memories because my first printer years ago was exactly like yours.
Best of luck with it!
mcdarren23
Re: Rostock max v1
Lol is it really that old. Haha. Is it actually going to be able to work ?
