As previous posted when I build projects I kind of look for the easier or simpler way of doing things, I would say better but for every better there is always another way that is better to some one.
OK, issues with the #6-32 nylon lock nuts in laser cut pockets. I had several issues with three of the these nuts.
First issue was I found a couple of the screws used into the nuts had dings on them which bound them up on the nuts. This resulted in the nuts turning in pocket in both directions (in and out). Not able to remove the screw or tighten it in further.
Second issue was I had one laser cut pocket fresh out of the box that was half chipped out on one side. This pocket I was worried on it crushing when tightening.
And third was the loose pockets that had to have nuts taped in place. I had three of these, I found two being just a wee bit to loose for even tape to work at holding them well enough to prevent them from turning.
So how to get these to tighten down when all they do was spin?
Well back to my handy dandy harbor freight and search for a solution.
I found a long reach set of 10 inch vise grips, these had long enough jaws with enough gap in them to only touch the nut and clamp to it while I tightened the screw down. A clean grip of nut with no damage to housing or pocket.
As for the chipped out corner. I used a piece of brass hobbyist flat stock that was just wide enough to fit across the pocket. I cut it a 1/2 inch wider then the width of the board. Drilled/punched a hole dead center large enough to accept the 6-32 screw and bent 1/4 inch on each side to form a channel washer. No more worry on the nut pulling down to far. In hindsight I kind of wish I had made one of these brass channel washers for each pocket nut (would have been a bit over kill maybe but long term peace of mind on a more solid pocket for a small cost and effort). (maybe on the top half).
ROSTOCK MAX V2 #6-32 nylon lock nuts in laser cut pockets
- SPICETRADERS
- Plasticator
Post by SPICETRADERS »
- IMG_1512.jpg (30.74 KiB) Viewed 3073 times
==If it is not HOT and SUNNY then the END is NEAR==
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- Software
- ↳ Orca Slicer
- ↳ SuperSlicer
- ↳ Cura
- ↳ Simplify3D
- ↳ Slic3r
- ↳ KISSlicer
- ↳ Repetier Host
- ↳ OctoPrint
- ↳ Other
- ↳ Sculptris
- ↳ OpenSCAD
- ↳ FreeCAD
- ↳ Blender
- ↳ SolidWorks
- ↳ AutoDesk 123D
- ↳ EMC2/LinuxCNC
- ↳ Skeinforge
- ↳ Mach3 Software
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
