First layer not sticking problem
ximeng
Post by ximeng »
Hi everyone,
I'm using an ORION printer, a problem came up that the first layer is always not attaching to the bed.
I'm using PLA, extruder 200/bed 60. One layer of white gaffer tape on glass heated bed. I've tried a lot of different Z height, from too far to too close to bed. They were all not working.
Any suggestion? I notice that when I run tower g-code file, nozzle seems to scratch tape when moving to one of the towers. Could it be a bed leveling issue?
Re: First layer not sticking problem
Post by Mac The Knife »
Yes.
ximeng
Post by ximeng »
update: I fix the leveling problem by adjusting screws, but PLA material is still not sticking to gaffer tape, i'll upload some image later, please, guys, really need help here.
ximeng
Post by ximeng »
these are two picture of my first layer print
ximeng
Post by ximeng »
some settings i'm using, i've tried different first layer height, it's not working
Tincho85
Post by Tincho85 »
Have you tried with different bed surface materials?
Uhu glue, blue painters tape, kapton tape, PVA glue. Those are good candidates.
Directly to glass with the bed at 60ºc worked for me too.
PEI sticks really well, but that's another cost.
Martín S.
Windshadow
Post by Windshadow »
remove the gaffer tape and try the recommended things that Tincho85 listed
ximeng
Post by ximeng »
Hi all,
Thank you so much for your suggestions,
I switch my surface material to the blue painter tape, it's working pretty well,
Another key change is that I use an piano wire to clean up the nozzle, somebody must leave some burned PLA causing a jam in nozzle. Once the material could be extruded smoothly, the first layer is sticking pretty good.
I really appreciate your help, which makes my life much easier when my boss put me to this 3D printer assignment, I never used one before.
