Should I expect to get better than this? Excuse the upside down pics. They are right side up when you click on it.
Gray PLA
.14layer height.
Is this print ok?
Qdeathstar
Re: Is this print ok?
it is a nice print, but yes. you can do better. I think you are underextruding just a little bit... or you are printing just a bit fast, as you can see gaps in the outer shells.
Qdeathstar wrote:it is a nice print, but yes. you can do better. I think you are underextruding just a little bit... or you are printing just a bit fast, as you can see gaps in the outer shells.
Thanks, there is no gap to see in person but the camera picks up stuff like that. I used gray to show any flaws.
- DeltaCon
I am pretty sure there are gaps between the perimeters. Maybe a picture taken more from above would convince me otherwise
Bit the vertical surface looks really smooth so that's great. Is it a small brim I see on the bottom? If not intended as a brim your first layer height should probably be raised.
