Pillowing vs over extrusion
Qdeathstar
Post by Qdeathstar »
Hi,
I have this print I am trying to print and I am having some issues with the top layer.
I'm sure part of my issue is pillowing.. But I increased the top layers to 10, and the top surface is still pretty rough.
Do you think this is due to pillowing or over extrusion? My other prints that don't have huge flat tops seem ok....
I'm not running any cooling currently, but that will change soon.
lightninjay
Re: Pillowing vs over extrusion
Post by lightninjay »
Your last line of "not running any cooling" should be your magic bullet.
Cooling is essential to let the plastic bridge properly on top layers. Once you have proper cooling, try it once more with between 3 and 5 top layers.
Qdeathstar
should have said before.... this is abs, so, cooling stil a factor?
lightninjay
In some cases, cooling with abs can be a good thing. If you want to try, you can lower your printing temps a bit.
Tincho85
Post by Tincho85 »
Agree, I do use cooling fans for ABS. Mostly at 20% fan speed, for bridges, overhangs and last layers like yours with a lot of detail.
For structural parts is not recommended as you can have some delamination.
Also, polish the tip of your nozzle a bit.
Martín S.
TIL Stormtroopers can't hit print settings either. *grins, ducks, & runs* :D :D :D
You wearing your red shirt today, Gene?
Stormtroopers can probably hit that, still.
joe
Post by joe »
Tincho85 wrote: Also, polish the tip of your nozzle a bit.
I polish the tip of my nozzle as often as possible.
Nah. They'll miss, but I'll still die. :D
lightninjay
Polishing the tip of your nozzle can help to prevent build-up, and promotes a happier printing mind-set. ;)
joe
Post by joe »
I could not agree more. :D
Tincho85
Post by Tincho85 »
It took me some time but finally got it :o :D
Martín S.
