Hello all,
Which parameter in Rambo firmware configuration will change active extruder motor port from E0 to E1? without other changes?
(If it is possible).
Extruder motor on E1 instead E0
Re: Extruder motor on E1 instead E0
Look in "pins.h". Search for "301" to find the Rambo section:
scroll down to find
Change the labels to swap E0 and E1. Add a comment to remind yourself.
#if MOTHERBOARD == 301
#define KNOWN_BOARD
* RAMBo Pin Assignments
******************************************************************Code: Select all
#define E0_STEP_PIN 34
#define E0_DIR_PIN 43
#define E0_ENABLE_PIN 26
#define E0_MS1_PIN 65
#define E0_MS2_PIN 66
#define E1_STEP_PIN 33
#define E1_DIR_PIN 42
#define E1_ENABLE_PIN 25
#define E1_MS1_PIN 63
#define E1_MS2_PIN 64Code: Select all
// E0 and E1 swapped!
#define E1_STEP_PIN 34
#define E1_DIR_PIN 43
#define E1_ENABLE_PIN 26
#define E1_MS1_PIN 65
#define E1_MS2_PIN 66
#define E0_STEP_PIN 33
#define E0_DIR_PIN 42
#define E0_ENABLE_PIN 25
#define E0_MS1_PIN 63
#define E0_MS2_PIN 64
