Led light ring powered off the accelerometer board?
Bock
Post by Bock »
Are there any issues running an LED ring off of the accelerometer board, preferably off the unused led pin? If that isn't a good pin to use, any others that will work?
Thanks
bvandiepenbos
Re: Led light ring powered off the accelerometer board?
Post by bvandiepenbos »
The LED connection on probe board works fine for LED light ring. That is how I have mine hooked up.
Bock
Post by Bock »
Thanks! Any chance you can show a picture of your setup?
duvdev
Post by duvdev »
What is the diameter if the led ring?
bvandiepenbos
duvdev wrote:What is the diameter if the led ring?
I can't remember and I am out of town until Friday.
But there is a model on repables.com
edit, here is link to model http://repables.com/r/554/
size:
Trick Laser LED Light Ring http://www.tricklaser.com/LED-Light-Rin ... D-RING.htm I.D. = 42 mm O.D. =58.2 mm PCB thickness = 1.6 mm (6) 4.4 mm diameter holes, evenly spaced on 50 mm diameter center line.
Last edited by bvandiepenbos on Wed Oct 12, 2016 10:55 pm, edited 1 time in total.
bvandiepenbos
Bock wrote:Thanks! Any chance you can show a picture of your setup?
here you go...
TMIB
Post by TMIB »
I have mine wired to the hot end fan leads. I figured that if the new setup has the fan on all the time that I could just hook right in there. Makes for a clean install, and keeps my LED light ring on whenever.
I'm not worried about doing the mod to turn the fan off at lower heat, as the noise is a non-issue for me. The PCs in the same room have some pretty loud fans, and the printer is certainly not the noisiest thing in that room.
The Trick Laser ring mounts very nicely to the HE280 hot end. I used the spacers that came with it, and slightly longer mounting screws, and just lined up 3 of the holes in the ring with the 3 screw locations centered on each fan location.
Noircogi
Post by Noircogi »
I found that a 60mm ring was just the right size to fit inside my modified fan shrouds.
I'm using a cheap one from Amazon ( 2 for $7 ), it's a nice medium brightness. If you want a "flashlight" look, get a different one.
[img]https://cdn.thingiverse.com/assets/6c/c ... D_Ring.jpg[/img]
Mounting clip model is on thingiverse: http://www.thingiverse.com/thing:1845789
Penged
Post by Penged »
Is there a way to switch the light ring on and off if you wire it to the HE280 board?
V2 max with the HE280 hotend
Return to “RostockMAX v3”
