Where does your Umbilical rest?
cassetti
Post by cassetti »
Mine seems to like to rest along the Z axis. Has anyone else had this issue? How are you guys supporting your filament and wire bundle so it doesn't come into contact with the delta arms, or does it matter?
Haven't noticed any real impact, but I'd like to remove as many physical variables as possible as I practice printing larger objects on the Rostock.
[img]http://farm9.staticflickr.com/8266/8645 ... 4640_c.jpg[/img]
rs50pilot
Re: Where does your Umbilical rest?
Post by rs50pilot »
Mine is about the same. I just took a scrap piece of filament and loosely looped it around. Works well looks like an after thought. When I have time ill just use a small bungee or something.
Batteau62
Post by Batteau62 »
I have something like this (somewhere?)
plastic spring
plastic spring
plastic spring.jpg (72.57 KiB) Viewed 5965 times
I'm thinking connected to the top plate center-then midway on the umbilical.
If I find it.
cjdavis618
Post by cjdavis618 »
I keep my bowden tube seperate from the wires. I didn't but any split loom or conduit over any of it. The wire is plenty strong to support it from the head to the place I have tied it off too.
[img]http://i5.photobucket.com/albums/y176/cjdavis618/rostock/BCFE5C84-C358-4149-BF1F-00AFFDB673B3-462-00000076D2004273_zpse62d132f.jpg[/img]
cassetti
Post by cassetti »
Interesting, but i'm thinking of something else, perhaps a retractable ID card holder would do the trick... Gotta dig through my basement and see if I can find one
jesse
Post by jesse »
I just let them hang down. There's a loop through the wooden circle for the thermistor so it can't be tugged out.
[img]http://i.imgur.com/lgsafEa.jpg[/img]
Return to “Rostock MAX”
