Re: kbob and Impulse, the Rostock MAX
Posted: Thu Aug 08, 2013 9:46 am
As a carpenter/furniture-builder guy, I dig the inlay. The print seems pretty good, too. Did you build the desk?
Have a look around and join today!
http://download.seemecnc.com/forum/
My friend Jacque built the desk, but I "helped".doctorgonzo wrote:As a carpenter/furniture-builder guy, I dig the inlay. The print seems pretty good, too. Did you build the desk?
It looks like my last post about calibration was on July 18th. Between then and now, my printer has been inoperable most of the time for a bunch of reasons.ApacheXMD wrote:So your measured geometry values worked out well I presume? That hollow cube looks pretty good!
Have fun. It was an odyssey.JohnStack wrote:Great post, trying it in a couple of weeks.
"Ah, yes. The old paracord motor wire sheath trick." — Maxwell Smartgeneb wrote:I'd love to learn more about the "paracord sheath trick" you used.
http://www.dickssportinggoods.com/produ ... d=16176856geneb wrote:All the original wiring in the F-15 is covered with the stuff. I do like the idea of using the paracord though - I'll have to see if I can find a local supplier. If I ask at some place like Dick's Sporting Goods, will they know what I'm talking about?
tnx.
Can you tell me the approximate ID of the Paracord. I assumed it was 1/4" from the looks of it.kbob wrote:Thanks, guys. I am familiar with "store bought" cable sleeving products. But paracord has a completely different texture from the cable sleeve I've used. It is much softer and more flexible, and it frays less (even before you melt the ends). I assume it's because paracord is made from thinner fibers.
It is also limited in that it only comes in one size.
I think it's closer to 1/8". It stretches a little when it goes over a 5/32" tube. I have used it over larger wire bundles, but it looks better when it's not stretched.Eaglezsoar wrote:Can you tell me the approximate ID of the Paracord. I assumed it was 1/4" from the looks of it.kbob wrote:Thanks, guys. I am familiar with "store bought" cable sleeving products. But paracord has a completely different texture from the cable sleeve I've used. It is much softer and more flexible, and it frays less (even before you melt the ends). I assume it's because paracord is made from thinner fibers.
kbob wrote:I have a cheap dial indicator. I got it at Horr'ble Fright last year for another project. http://www.harborfreight.com/1-inch-tra ... r-623.html
I designed this nifty little mount for it. I designed and printed it back in June, but didn't get a photo of it on the printer until tonight.
Here's the real thing.
I made the central hole a little undersized. The three slots around it let the hole stretch to make a nice friction fit around the indicator's shaft. I'm starting to figure out how to design for ABS.
You can also see the hair scrunchies that tension the delta arms. There are three more up by the CheapSkates.
Here is the OpenSCAD source file.
My printer is back together now. I aligned the towers using the alignment jigs, I've changed the printer dimensions in the firmware, and yes, I've used this dial indicator to see how well it's aligned. I haven't had a chance to print anything yet.
More on that later; right now I just want to tell you that using a dial indicator to adjust the limit switches is about 20 times faster than sliding a piece of paper under the nozzle.
