Page 6 of 7
Re: Monolithic Platform for E3Dv6 Hot End
Posted: Sat Dec 13, 2014 11:40 pm
by Jassper
eatoutmikey wrote:
Thanks for the links, while that explains what it is....... there are no dimensions given. A step file would be best if someone can find one but at the very least, outside dimensions and mounting screw locations are needed. Same with led.... what is the diameter between the screws? (i'm assuming there are 3 so you cant just measure screw to screw)
The mounting screw dimensions are the same as the SeeMeCNC Hot end plate, if you need any specific measurements, let me know.
Posted: Mon Dec 15, 2014 6:03 pm
by predawnsky
got my e3d and did the mods
Posted: Tue Dec 16, 2014 4:08 am
by add1ct3dd
Anyone find it a pain to print the mount?
The huge accel on the Rostock causes it to lift up the first layer, usually on those inside bolt holes, my only solution so far is to reduce the travel speed, but not really a fan of doing that!!
And does anyone know if we can get those white bits for the arms, the metal rod that goes through and the plastic bit that goes around it (as the pic above), that would make swapping hotends way easier!
Ideally in the UK, shipping from US takes forever and is expensive :]
edit: Solved the adhesion issue by making some ABS juice :)
Posted: Wed Dec 17, 2014 10:27 pm
by BONE
Predawnsky, that looks sweet! Good job.
Alright, I'm back!
I have my latest model of the platform installed, but it just missing a few things. I print mine out of PLA and they work great if you only print PLA with it. I tried printing ABS for one job and warped the paltform with the high temps in the enclosure. Not good. Have a find print me a ABS version soon.
I installed the stepper dampers which makes a difference, but it's not as huge that I though it would be. The GF can sleep with it running overnight, so that enough for me. I took decibel reads and they were the same near the machine and in the room next to it. The coarseness of the sound is reduced, so thats nice.
The Trick Laser arms are installed and they look so much better then the old fat ones. Used the hardware that came with it for the cheapskates, used M3 machine screws for mounting to the platform. Putting the locking nuts on the M3 rods that come with the arms are a pain to put on.
Still have to install the LED ring and the Yellow Jacket Board.
Here's a dark shady video of it printing.
[youtube]http://www.youtube.com/watch?v=-J0uVDbkh30[/youtube]
Posted: Thu Dec 18, 2014 5:17 am
by add1ct3dd
Awesome, how does the hotend print vs stock with PLA? I primarily use PLA so this is the big factor for me!
I have the hotend anyway, so if worst comes to worst, I'll just build a new printer to put it on :D
Posted: Thu Dec 18, 2014 9:45 am
by critical_limit
predawnsky wrote:got my e3d and did the mods
Any chance to get the Files?
Posted: Thu Dec 18, 2014 10:24 am
by BONE
There are some old files in the previous posts. I'll upload my more current models soon. I've been delayed in doing this with other life activities.
Posted: Sun Dec 21, 2014 10:03 pm
by BONE
Here is the latest Solidworks file, have fun with it. Also, there is a loT of junk features that I just keep adding, so be careful. It needs some cleaning up.
Layer fan has not been design yet and I think a fan mounted on the outside will hit the arms in some cases.
And, remember this a work in progress and you will probably need to play with it. HAPPY HOLIDAYS!
You'll also need the groove mount holder.
http://www.themakerhive.com/FTP/jassper/gmc.stl
Posted: Mon Dec 22, 2014 4:25 am
by add1ct3dd
No stl for the main file? :( Damn, I don't have solidworks!
Posted: Mon Dec 22, 2014 4:55 am
add1ct3dd wrote:No stl for the main file? :( Damn, I don't have solidworks!
Could some kind member convert the Solid Works file to an STL for this member? Please :)
Posted: Mon Dec 22, 2014 5:03 am
by bot
Ask, and ye shall receive.
E3D v6 Platform 30mm fan v2.STL
(1.2 MiB) Downloaded 602 times
Posted: Mon Dec 22, 2014 5:50 am
bot wrote:Ask, and ye shall receive.
Thanks Bot!
Posted: Mon Dec 22, 2014 7:52 am
by BONE
I uploaded the STL file for this one on my Nov 20th post. Someone had requested the source file, so I uploaded it.
Posted: Mon Dec 22, 2014 12:05 pm
by add1ct3dd
Thanks guys :)
Got my E3d V6 here, but may wait until you find a way to add layer fans (hopefully we can get 3 on like the stock mount?)
That'd be perfect then :).
Posted: Mon Dec 22, 2014 1:17 pm
by BONE
add1ct3dd wrote:Thanks guys :)
I'll have to work on that. Maybe over the Holidays. But I just got my PEI and copper sheets in, so I'll be playing with upgrading the heat bed also.
Posted: Mon Dec 22, 2014 1:48 pm
by add1ct3dd
No rush, printing is still fine with stock hotend :) I can just keep looking over at the E3d and wipe the drool every now and again :D
Posted: Mon Dec 22, 2014 2:11 pm
by BONE
add1ct3dd wrote: No rush, printing is still fine with stock hotend :) I can just keep looking over at the E3d and wipe the drool every now and again :D
What is preferred by everyone? 3 squirrel fan on the sides or 1 bigger fan with a duct surrounding the hotend?
Posted: Mon Dec 22, 2014 4:04 pm
by crocky
I will be going for the single duct and a bigger fan, haven't done much yet though... Idea's at this stage!
Posted: Mon Dec 22, 2014 4:51 pm
by BONE
Hey Crocky,
Are you using the model I uploaded or generating your own? Can't wait to see it.
Posted: Thu Jan 29, 2015 7:36 pm
by matter68
Do you have any pics of it with the Yellow Jacket installed yet? I'm looking at mine and it appears I'll have to move the fan mounts and thermistor plug to the top of the board so it will lay flush.
Posted: Sat Jan 31, 2015 5:04 pm
by BONE
No, nothing yet. I've been printing, but the printer project have been put on hold. Got to find some time to tinker.
Posted: Sun Feb 01, 2015 6:23 am
by add1ct3dd
Is anyone using it with PLA? Struggling to find how to mount any cooling fans :(.
Posted: Sun Feb 15, 2015 2:24 pm
by predawnsky
add1ct3dd wrote:Is anyone using it with PLA? Struggling to find how to mount any cooling fans :(.
i use the mount mostly for pla
Posted: Wed Feb 25, 2015 9:56 pm
by matter68
These mounts look fantastic. I need to be able to mount a yellowjacket one though.
Posted: Sun Mar 01, 2015 12:15 pm
by add1ct3dd
Anyone kind enough to share their E3d retraction settings for PLA?
Currently retracting 3.1mm at 50mm/s, Z-lift 1mm and minimum travel for retraction at 2mm. It's good for most prints, but still getting some stringing, can't seem to fully stop it!
