Re: Keep losing my balls.
Posted: Wed Sep 18, 2013 8:58 am
Can you solder the balls to the screws? It seems like it would be a comedy of errors unless you had a real good grip on that iron.
Have a look around and join today!
http://download.seemecnc.com/forum/
I would say no, but here is someone that did: https://groups.google.com/forum/#!searc ... TpB2oSBrEJ626Pilot wrote:Can you solder the balls to the screws? It seems like it would be a comedy of errors unless you had a real good grip on that iron.
Find someone with an EDM machine? Hm... that'd be a neat attachment for the rostock....Flateric wrote:If someone has found a fast easy and cheap way of drilling and tapping steel ball bearings, PLEASE speak up and tel me how you are doing this. Because I cannot see this being, fast, easy, cheap that I can think of.
What is the source on the balls? We already had a post about the traxxas balls and those look very similar.notarat wrote:What size are those balls you guys JB Weld to the screw heads?
Just wondering because I found some ball studs that might possibly be used if they're the right size.
[img]http://www.beadlok.com/product/images/5 ... SC6275.jpg[/img]
Imagesearch leads me to these sites:Eaglezsoar wrote:What is the source on the balls? We already had a post about the traxxas balls and those look very similar.notarat wrote:What size are those balls you guys JB Weld to the screw heads?
Good point, and I already have the Traxxas balls that are on the stud so I'll keep my plans to use those.Polygonhell wrote:They are #4 nuts which I believe are 1/4 inch in diameter, so the balls are probably < 6mm.
That is the problem with the Traxxas balls, they are sold in both the aluminum and steel versions and you have to be sureFlateric wrote:I could be wrong, but the balls pictured there, look very aluminium....?
