Page 2 of 2
Re: The build has begun!
Posted: Thu Dec 05, 2013 1:56 pm
by t1tch
Ok... forget that: yes my LCD is blank, but as the printer only prints dry runs now - I obviously have a more fundamental issue :D
Posted: Fri Dec 06, 2013 11:16 am
by t1tch
Prety much went round in a big circle - learned a bit, and arived back at the beginning with the SeeMeCNC firmware, so I recon I must have treaked a veriable that was happier untweaked. Only now the hot end consistantly maintains a temperature that's 5 deg lower than the target - probably another inapropriately tweeked setting.
This fault chasing is pretty good fun, not sure what I'm gonna do with myself once I've got it printing the way I want... :D
Posted: Fri Dec 06, 2013 12:07 pm
by ccavanaugh
If wanted, I can upload my build based on the latest Repetier devel branch. LCD is working just fine and you can just tune your settings from mine. The advantage is not having to worry about the freeze during print bug.
Posted: Fri Dec 06, 2013 12:10 pm
by t1tch
ccavanaugh wrote:If wanted, I can upload my build based on the latest Repetier devel branch. LCD is working just fine and you can just tune your settings from mine. The advantage is not having to worry about the freeze during print bug.
Yes please! :D
Posted: Fri Dec 06, 2013 12:21 pm
by ccavanaugh
Here you go!
Tested with Arduino IDE 1.0.5
Just copy over your delta settings, speeds, etc, although as set, I am getting nice results. I have enabled the hotend/Peek fan to run automatically if above 40C in temperate or when turned on. This means it will run for awhile after a print job completes.
Repetier.zip
(256.69 KiB) Downloaded 313 times
Posted: Fri Dec 06, 2013 12:36 pm
by t1tch
ccavanaugh wrote:Here you go!
Great thanks ccavanaugh hopefully this will solve all my problems :lol:
Posted: Sat Dec 07, 2013 5:16 am
by t1tch
...Realy should learn to not say things like that even in jest - one of my hydraulic couplings failed last night, bit of a shame as it's not even a month old... Fortunately there's a hydraulics place round the corner. So back up and running this morning and time to take ccavanaugh's kindly donated firmware build out for a test drive. Thanks again - I'll try not to scratch it :D
