Concentric layer fan shroud
srgntforest
Post by srgntforest »
hey everyone, I've had this up on thingiverse for a bit, and figured its would be good for the community. The design improves on the original, and removes the need for extra layer fans. http://www.thingiverse.com/thing:1377757
BTP
Re: Concentric layer fan shroud
Post by BTP »
Nice design I may give this one a go.
http://www.benchtopprecision.com" onclick="window.open(this.href);return false;
E3D V6 Mount -->> http://benchtopprecision.com/e3d-v6-mou ... tockmaxv2/" onclick="window.open(this.href);return false;
Neptune
Post by Neptune »
I printed this design, I really like it but with my e3d v6 it is too close to the heater block and it started to droop/melt. I even printed it in ABS....may have to try it in Nylon or something higher temp...
Saber
Post by Saber »
Neptune wrote:I printed this design, I really like it but with my e3d v6 it is too close to the heater block and it started to droop/melt. I even printed it in ABS....may have to try it in Nylon or something higher temp...
You could try putting a small layer of aluminum foil or something on top of it as a heat reflector, or maybe just make it wider diameter so it's not quite as close.
Post by Xenocrates »
Let's see, Protopasta has HT-PLA which when annealed should reject more heat. You could also use duct tape (Not duck, but the aluminized stuff) to cover the top surface. Personally, I like the Berd air as a concept (But I still have to nail down a good mount for it), as it's all aluminum.
Neptune
Post by Neptune »
Xenocrates wrote:Let's see, Protopasta has HT-PLA which when annealed should reject more heat. You could also use duct tape (Not duck, but the aluminized stuff) to cover the top surface. Personally, I like the Berd air as a concept (But I still have to nail down a good mount for it), as it's all aluminum.
I like the idea also, but just don't like the external pump bit...
