joint vs ball cup joints
Posted: Mon Mar 21, 2016 5:29 am
I have upgraded my v2 with the carbon fiber arms from trick laser. (here)
How do I determine my Diagonal Rod Length? In the software manual it says:
On the trick laser website it says:
I'm not sure whether to set my Diagonal Rod Length to 290.8, or to 269. Any help/photos is appreciated, thanks!
How do I know if I have the u-joint based arms? What do they look like?Open the EEPROM editor and check the values shown below. If the Diagonal Rod Length parameter isn't set to 290.8, please change it to that value. The starting position for the Horizontal Radius is 144.
If you're working with an older v2 or v1 with the u-joint based arms, your Diagonal
Rod Length should be 269 and your starting Horiztonal Radius should be 130.25
What do the Ball-Cup arms look like?Note: OEM arm legths; v1 & v2 with "u-joint" ends are 269mm, Ball-Cup arms are 291mm.
